Lotus exige S Roadster 2013---Las manitas quietas que nos conocemos!!!
  • 1 Respuestas
  • 1562 Vistas
Lotus Exige S Roadster
si señores!!     Tremendo bicharraco con lo bueno del Elisse  y los extras de conford y lujo del EXIGE...
http://www.seriouswheels.com/cars/2013/top-2013-Lotus-Exige-S-Roadster.html
Price €55,378 Production --
Engine 3.5 liter V6 Weight 2571 lbs
Aspiration superchargerTorque 295 lb-ft
HP 345 hp @ 7000 rpm HP/Weight 7.5 lbs per hp
HP/Liter 98.6 hp per liter  1/4 mile --
0-60 mph 3.8 seconds Top Speed 145 mph
The Exige S Roadster at a glance:
• Max Power 345 hp (350 PS) at 7000 rpm
• Max Torque 295 lb ft (400 NM) at 4500 rpm
• 0 – 60 mph 3.8 seconds
• 0 – 100 km/h 4.0 seconds
• Max Speed 145 mph (233 km/h)*
• Weight 1166 kg
The Exige S Roadster in more detail:
Engine: Mid-mounted, transverse 3.5 litre DOHC V6 VVTi, 24-valve equipped with Harrop HTV
1320 Supercharger.
Transmission: 6 speed manual with sports ratios only from launch. Paddle shift options for Exige S Roadster will be considered subject to demand.
Suspension: Fully independent double wishbone suspension with front and rear anti-roll bar. Bilstein high performance gas dampers and Eibach coaxial springs.
Braking & Dynamic systems:
• AP-Racing four-piston callipers with ventilated and cross drilled cast-iron discs.
• Lotus / BOSCH Developed ABS/ESP system
• Hydraulic Brake Assist (HBA)
• Electronic Brake Distribution (EBD)
• Cornering Brake Control (CBC)
• Lotus Dynamic Performance Management (Lotus DPM)
Wheels & Tyres: Lightweight cast alloy wheels (17" front and 18" rear) clad with Pirelli P-Zero Corsa tyres.
- See more at: http://www.seriouswheels.com/cars/2013/top-2013-Lotus-Exige-S-Roadster.html#sthash.MX90ggp8.dpuf
para más fotos,  teneis la web...      joeeeeeeer    que wappo!
